super99
My 77 gas was surging really bad, took the governor housing off and the little spring was missing. I put a different housing with a spring in it and when I got it set not to surge, the nut on the adjustment was clear in against the head of the screw. It set inside all winter and then when I started it this year, it is surging again. No threads left to tighten the screw to stop it. Do the springs get weak? The I&T manual says to tighten the screw until surging stops, which I did. Now it's surging again, so what do I do now?? I have the rods set where they are supposed to be. I have looked at other tractors, most all of them the nut is set near the middle of the adjusting screw. Is the happy spot in the middle of the adjusting screw and I missed it and went too far? I'm confused! Thanks, Chris
