Farmall 100 tractor progress
crsutton81
We got the 100 home from where the
front end met with misfortune.
Figured out a way to ratchet strap
and chain the axle under it enough
to load it on the trailer. Was quite
nerve racking to say the least to
drive it onto the trailer !! Got it
tore down today and it looks to only
need the upper part of bolster
gearbox with a bearing/reseal job to
fix it. I was afraid it could take
more than this on first glance. Need
to go pick up parts and clean up
then time to reassemble to get it
out the door.
<img
src=https://www.yesterdaystractors.com/cvphotos/cvphoto105344.jpg>
<img
src=https://www.yesterdaystractors.com/cvphotos/cvphoto105345.jpg>
Glad you got her home and disassembled. Hopefully, you didn't need a couple of turns of baling wire around it to get it stuck together enough for trailering. Good luck on getting it all back to working. Steve
No one was hurt but I could have hurt them for being careless to cause this. This is one of those jobs that is above duct tape, bailing wire, and zip tie fixes. Lol.
Hope someone did not try crossing a ditch or gully straight ahead. I have told my youngun, wife, and tobacco help many times in the past to cross at an angle, slowly. I had an older neighbor break the front bolster from a Farmall H. That was not a pretty sight.
On another item, we made it to the fair on Monday. The displays around the tobacco barn were great. The remodeled barn has lost its much of its nostalgia, but necessary for liability reasons I guess.
I have seen the mechanical looping machine there many times, but never seen one of them in action. It looks like it would keep everyone busy. That use to was always a problem in the field after lunch break here racking in the field and sounds like in the past with stick barns. Everyone would get distracted telling what happened on the Young and The Restless that day at dinner time.
We put all our baccer in stick barns until we quit growing it after the buyout. We were a small operation, only grew 8 to 9 acres a year. We did most of the work ourselves until priming began. We would pull enough to fill a barn in the morning, and most of the same crew would help us string it afterwards, and finish between 1 and 2pm. A farmer we swapped help with bought a rack barn a few years before we both quit.
We'd back the stringer through the barn door. 4 people worked best on the stringer, 2 emptying trailers, 1 taking sticks off the stringer and handing them up to a person hanging it. We tried to string 5 sticks a minute if things were running good. They will string 7 a minute.
We chose not to grow. Being surrounded by too many towns and cities was the main reason.
It was all stick barns when grandaddy was in charge of the farm. I just do remember taking a barn off the sticks and grading it the first year dad took over. He started out with rack barns cropping by hand with a Davis harvester racking it in the field. We changed all of the barns to boxes in the late '90s when good help started to get hard to get. Eventually went all mechanical as possible till about 5 yrs ago. Went back to cropping by hand the first 2 times.
