farmall 656 hydraulic problems
princess
I lost the hydraulic pressure and the power stering all at once. The pump was checked and it works fine. It blows air out of the port where you check the pressure, but it doesn't pump oil. Does it have a suction tube on it? If it does how do you get to it? I have talked to the local repair place and they don't know what is wrong.
theres a tube with a rubber piece on it between the pump and the hydro filter just replaced ours last week it got where you would have to wait a good while for it to pick the fluid and it was getting worse and was noisy cavatating now its quite as a mouse. bout thirty bucks at the dealer
