I've been rebuilding a C-113 from a Farmall B 1943 vintage. I've had a few struggles, but the latest one has me scratching my head.
First off, I wrecked the crankshaft trying to get the pulley off of it. It was pretty wore anyway, so I didn't care too much. I just got a .010 reground one. It came with the gear, and it only has 1 mark like you would expect.
When I went to put the cam in, I noticed that there were more timing marks than there should be. The cam is the original, and someone maybe made some extra marks.
I have a couple questions If you experts could help me out. It has been driving me crazy!
1) With the crank at TDC #1, should the timing mark on the crank gear be pointing to the cam perfectly? I had to rotate mine 1 tooth to line up a mark with the cam gear.
2) When the cam gear mark is lined up correctly with the crank timing mark, and the governor timing mark is lined up with the cam gear, should #1 be at TDC and if so, on compression or exhaust stroke? Currently mine is at about 10 deg after TDC on the intake stroke, so something seems amiss.
3) Related to question #1... I'm wondering if there were different revisions of the crank gear for different engines with the mark off by 1 tooth. It would seem that you would want everything all at TDC when the marks line up. Mine is not. When I take my front cover I will count the teeth from the keyway to the timing mark and compare to the original. As I recall the original crank gear's mark is located on the 4th valley counterclockwise of the keyway.
4) Are the double marks for the governor, exactly 180 deg from from the single mark that lines up with the crank gear?
I have it in an engine stand still, and the head isn't on yet. I just have to pull the pulley off and the front cover, so now is the time for me to make doubly sure I get it right.
Seems like I'm off a tooth, and maybe 180 deg out on the cam.
I dropped the pushrods into the block, but it is somewhat difficult to monitor them accurately, but it seems like the intake valve starts opening pretty much at TDC. According to the service manual, it should be more like 15 deg After TDC. Kinda supports the one tooth off theory.
1st pic is of the governor lined up on the double punch.
2nd pic crank is rotated 1 turn to show the mark that I lined up with on the crank gear. Notice the confusing double strike and the other 2 punch marks
