farmall cub governor
blaineranger
Just bought 49 Farmall cub, and when we got it started it will only
run one speed, fairly high RPM. The throttle rod moves the
governor lever back and forth but RPM never changes. What do we
need to do?
The lever on the governor has a spring that connects to a linkage that controls the carb throttle butterfly. Check the spring I bet it's broken.
another thing to check is the bumper spring is not screwed in too far. it screws in from the front and has a locknut on it.you can loosen it off and because of the locknut position you can put it right back if that s not the problem. Dick
