Farmall H help
Jason keen
So I just got a farmall h and been researching it and found it does have a high low shift lever. But I'm trying to figure out the year also. The serial is FBH38473 X1. Any help would be appreciated. I am planning on fully restoring this tracter
Buy a set of books first. Owners,service,parts. Ask a lot of questions. Post pictures. Remember a fancy paint job is not a 'restoration'."areosol overhaul". Rather a (fairly) complete dismantle.Overhauled engine,transmission,clutch,tires ,new wireing harness..? costing many thousands of dollars.You decide to what level you want to go to.Post a current picture of your tractor,especially the extra shifter lever.If it is a real nice original,may be best to just clean up and shine,rather than ruin it with new paint.Personally,I prefer (clean) every'clothes' and nice originals.Much more interesting.Why have one that looks like everyone elses ?Seen one new paint job,you seen em all.
I been looking all over the internet on this shifter and I think it's the heisier 9 speed.
There is a SN list at the left side of this page. A 38,xxx H is a 1940 model. Did you know IH made over 380,000 Farmall H tractors?Aside from the 8N Ford at around 500,000,the best selling tractor ever.the complete N series(9;2;8N) over 900,000 copys.
Looks pretty good except for the cutout hood to accommodate the oversize alternator. Rear tires look like almost new.
You sure it's not a lever to operate the belt pulley gear box without bending over so far. Make sure you got all the serial number, it has some feathers later than 1940. Could be added to tractor later but wouldn't hurt to be sure. Engine serial number should match the chassis. Short oil filter housing, transmission top cover with 4 mounting bolts for seat assembly and later instrument box. Has a distributor instead of a magneto but common to find them to replace a Mag.
(quoted from post at 08:29:56 04/03/19) So is this a factory option they added on some cause it dont look aftermarket
Any nine speed was dealer or owner added. But that does look like a lever to assist with the belt pulley engagement. Does it engage and disengage the belt pulley (disc with holes next to it). That whole casting is the belt pulley gearbox.
Tractors for the most part do not have year models. Farmall H was made from 1939 to 1952 when the next model, Super H replaced it. Serial number lists show what year the unit was made. Of course 2019 cars are made from August 2018 to June 2019 or something like that.
Changes that were made within a model run were done at a particular serial number, not associated with a year model. There is also a date code on the major castings which will tell you the day the casting was poured. It may be several weeks to several months before the tractor was assembled.
I see nothing in any of those pictures that looks like a Heisler, M&W, or any other brand of over-drive unit. Only thing I see is the belt pulley gear box..
(quoted from post at 18:02:49 04/03/19) That is a belt pulley lever to engage and disengage the pulley.
They made a few H's in 53 still. They still had the band brake.
Some of the '53s had the disc brakes.
