farmall H hydraulics
J.C.
I've got a single hose out of the left side of my tractor. Does that only lift the implement? Also there is no hydraulic fluid on the dipstick when I checked it? How much and what kind of fluid should I use? Any help in regards to hydraulics would be helpful.
J.C.
1) The H (belly pump) has only one-way hydraulics - all three ports (one on left, two on right) are tied together.
2) Depends on how the cylinders are hooked up! ;->
3) Sounds like you need to add oil. Fill per dipstick or as required to achieve full hydraulic operation.
4) Original spec was for 30 Wt Non-Detergent oil.
Note:
If you switch implements between your H and modern tractors, you should use a compatible hydraulic oil to avoid a mish-mash of hydraulic oils in your tractors and implements.
Nathaniel
The single outlet on the right and both outlets on the left are pressure out and gravity return.
Original oil specs were SAE 30 non-detergent. If you are sharing with other implements use the same oil as they do.
