DelMN
I have a Harmall H that pops out of third gear. It doesn't happen under load, just when I decrease speed. Does anyone know what the problem/solution is?
Thanks in advance
Being a Heavy tillage gear, and decades of use, it is in need of some TLC. several things can contribute to the issue: It can have a worn intermediate (pilot) top shaft bearing, there could be worn/loose front main bearing set. The spring and ball detent could be rusted and failing, the gear teeth could be worn, and the shift fork could be bent some. Pulling the belt pulley (or blanking plate) can let you look at the system, but not fix much. Pulling the platform allows the vision to be improved. The top shaft front input shaft and intermediate bearing can be servoced/replaced without a split if the clutch shaft and coupler are taken out. The counter shaft cannot. Jim
I had a similar problem with a Case VAC. A look inside the transmission showed a very worn third gear. I always assumed that was from the operator trying to get it into gear before the transmission had slowed down or stopped. Grinding it in so to speak. I have a couple H Farmalls but never have been into the trannys. good luck gobble
