farmall single row tractor
Have a farmall not the cub, the hood has 100 emblem, it has the square front axle and the hand and foot throttle, it also has the yellow paint that is showing under the red , the serial number is on the clutch housing and has 166573 J, is there any way that I can find out if it is truly a 100?
That serial number does not match any production data for that tractor. If your serial number is 16573, where you added one too many sixes in the S/N, your tractor would be about an August, 1956 built Farmall 100. Production numbers for the Farmall 100 were serial numbers 501 - 1719 for 1954; 1720 - 12894 for 1955; and 12895 to 18940 for 1956. I did some interpolation to determine the approximate August, 1956 build date. Similar sheet metal IH tractors would be the Super A from 1947 with serial numbers from 25001 through 355679 ending in 1954; Farmall 130 tractors with serial numbers from 501 through 10209 from 1956 through 1958; and Farmall and International 140 tractors from 1958 through 1979 with serial numbers from 501 through 66790. Hope this helps.
(quoted from post at 14:49:38 01/26/20) That serial number does not match any production data for that tractor. If your serial number is 16573, where you added one too many sixes in the S/N, your tractor would be about an August, 1956 built Farmall 100. Production numbers for the Farmall 100 were serial numbers 501 - 1719 for 1954; 1720 - 12894 for 1955; and 12895 to 18940 for 1956. I did some interpolation to determine the approximate August, 1956 build date. Similar sheet metal IH tractors would be the Super A from 1947 with serial numbers from 25001 through 355679 ending in 1954; Farmall 130 tractors with serial numbers from 501 through 10209 from 1956 through 1958; and Farmall and International 140 tractors from 1958 through 1979 with serial numbers from 501 through 66790. Hope this helps.
Is there any way that I can find out if it was an industrial model? the square front axles, the yellow paint and the foot throttle are some indications?
