tractorsam
A little backstory - my 53 Farmall Super A has been sadly
neglected and under used for the last 5 years or so and has
developed a charging problem. After getting it going last year I
replaced the dud battery and it still wont charge. Its all
original and I messed around with the regulator to no avail, life
happened, winter came, and now Im trying to get to the
bottom of it.
I was thinking my issues lay within the regulator (as old as the
hills) but Ive verified my ammeter (both ways), and if I ground
the field coils I can hear the engine load up but the ammeter
reads a significant discharge (and my multimeter confirms the
battery voltage dropping). I have attempted the motor test on
the generator and if I power the armature it motors nicely.
With the field grounded, it will not motor. If its motoring and I
ground the field it rapidly slows and even appears to try and
reverse. Im thinking the field coils of my generator have
failed. Does this seem correct? Thanks, Sam
bottom of it.
