Farmall Super A
Don Yoder
Just purchased a Super A - Has been modified with a three point power lift added - unable to locate Serial# on seat bracket - looks like seat bracket has been modified - how do I determine which engine it has for restoration? Bell housing has 8638 DA on left side which is no doubt a casting number.
Look on the engine block below No1 sparkplug for a flat surface for the serial number. It may have layers of paint or grease and dirt. Should have a 6 digit number. Hal
You wont know the bore size untill you remove the head as over the yrs kits that were overbore were installed so you cant tell intil the head is removed and i would even remove a piston to see what type they are.
