Finished planting corn
tomstractorsandtoys
Planted my last field of corn for the year today. I chopped small grain silage this morning and notilled corn for silage this evening. Seems very late for southern WI. Usually I would have planted soybeans but this field has water hemp very bad and it is much easier to deal with in corn. The field is a creek bottom and I planted it deep and found some moisture. Will know more next Oct. if it was a good idea or not.Attached pic is from 2 years ago. Tom
Wow,that picture has so many memories. When I first farmed my father-in-laws half section, I used his 4010 narrow front with the two guides exactly like you have. On 38 inch rows and terraced side hills it worked well once you learned where to hold the chain. It was quicker to use than with the conventional JD 7000 markers when crossing a waterway and waiting for the markers to cycle. I always thought it looked like a cockroach with two guides sticking out like that. Thanks for the picture.
Beagle
I started farming with Allis Chalmers notill planters and this is what they used. When I bought my 7200 I tried markers for 2 years. They are just to slow and a pain when crossing waterways. You will get straighter rows using markers. My neighbors laugh but I tell them you get more corn in a crooked row. Tom
A tractor driver can get pretty good at planting straight rows with no marker if he can get a sight fix on some object straight ahead. Just be careful not to fixate on a resting stock cow that gets up and walks away. It happened over forty years ago and I still laugh at myself when I remember that mistake.
Given the rain lately, you didn't have a lot of choice. We've had 7 inches plus since June 1 in eastern WI. More than april May and june combined last year.
The corn will make silage for sure. What maturity did you plant?
I did my last field of corn on Wednesday. I'm not too concerned about it maturing, though the high today in NY's Southern Tier was in the low 50s, so maybe I should be.... Moisture hasn't been a problem so far.
I wish we had some of that 7 inches. We might have had 1 1/2 inches in June. The corn was 103 day so I guess we will be chopping in Oct. Tom
I think you will be fine.I have planted as late as July 4th for silage after taking hay off. Tho under 100 day silage corn in central wi.
I heard of a guy in SEMN who had 160 acres of corn to plant now. Guess the custom spraying didn't get the message he had planted conventional corn and hit it with Roundup a week ago. Ouch! That's why I spray it myself.
