fitting hydro motor
Supply from the pump outlet and return to the oil reseviour.
Sorry but I can't see from here, the make and model of the tractor.
(quoted from post at 21:11:51 04/17/10) the return line into the return oil line as well
According to the parts list on the JD web site. Do not dump the return oil back into the transmission. The oil has to be returned between the filter and the trans pump. The same way the factory scv's do. Otherwise the high pressure pump will starve for supply oil.
1 19M7179 CAP SCREW 2 X M10 X 50
2 R87590 CLAMP 1 X
3 28H3387 BUSHING 2 X 0.493" X 0.675" X 1-1/4"
4 T76938 O-RING 2 X
5 38H1196 ADAPTER FITTING 1 X
6 R29936 O-RING 1 X
7 T77858 O-RING 2 X
8 38H1048 ELBOW FITTING 1 X
9 F3171R O-RING 1 X
10 RE48001 HYDRAULIC HOSE 1 X (B)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. ALL REMARKS
11 14M7274 NUT 1 X M10
12 19M7179 CAP SCREW 1 X M10 X 50
13 T60996 ISOLATOR 3 X
14 19M8049 CAP SCREW 1 X M10 X 80
15 U46753 HOSE CLAMP 4 X
16 H141836 BUSHING 1 X
17 R112693 CLAMP 1 X
18 R44302 TIE BAND AR X
19 38H1164 ADAPTER FITTING 1 X
20 R29936 O-RING 1 X
21 F3171R O-RING 1 X
22 38H1163 ADAPTER FITTING 1 X
23 RE53562 HYDRAULIC HOSE 1 X (A)
24 19M7166 CAP SCREW 1 X M10 X 20
(A) PRESSURE (B) RETURN
PRESSION RETOUR
DRUCK RUECKLAUF
PRESSIONE RETORNO
PRESION RITORNO
TRYCK RETUR
