I was working on my new to me TO20 and noticed the tires looked low, so I went to fill them. When I took the valve stem cap off one side I heard air leaking out and what I thought was water sputtering out as well. On the other side, I took the valve stem cap off and a solid stream of a murky white liquid was coming out.
You'll have to excuse me as I'm new to the tractor world, are these tires fluid filled? If so, how do you pressurize the tire if there's fluid in it?
Also, do these valve stems not work like on my truck, where the Schrader valve needs to be depressed for anything to come in or out, or are these just bad?
Thanks!
Thanks!
