While back I have posted a problem on a Wisconsin TJD mounted on a Yazoo mower. Even though I have received great suggestions, the problem is still existing. Here is the problem and the diagnostic history.
First start, the engine runs perfect. After few minutes stops. Starts and runs again for few minutes, then quits again. (I like to point out that when the engine runs, it runs great).
Things I have done:
Right after engine stops, checked spark. GOOD SPARK consistently!!!
Installed carburetor kit and tested with spare carburetor.(Air intake adjusted)
Cleaned fuel lines, fuel filter and bowl.
Checked fuel pump output (.8 oz. in 30 sec.)
Installed new spark plugs and wires.
Installed new coil, points and condenser (last year)
Cleaned air filter and engine cooling fins.
When engine stops, cylinder head temperature is 225 deg. (normal??)
There is NO heat cutoff switch installed.
Oil level is okay.
Checked gas cap vent
Removed head and removed carbon build-up. Valves appear to be in fair shape. Did not see any major burns.
Spark plugs, especially #1 fouls quickly.
Did not see any manifold gasket problem.
Compression is 98 psi on both cylinders
What I also noticed that the engine is starving for gas. When the engine is about to die, I gave a shot of starting fluid and keeps going.
Also, after the engine quits, there is hardly any gas left in the bowl, but the pump out put seems to be adequate. (Fuel lines and filter have checked several times)
What I plan to do now, unless I get advices to the contrary, bite the bullet and order a new set of valves, new fuel pump, head and manifold gasket.
I just have to resolve this problem. (My grass is getting tall). Thanks again.
Things I have done:
Oil level is okay.
