dpendzic
Looking to up grade from my ford 1310--looked at a ford 1720 this weekend--1998,$7200--needs tires and tie rod ends---any inherent problems with this model??
They are excellent little tractors but that price is way too high, especially needing tires and work, either that or the compact tractor market in your area is very tight.
I have one, a 1994 model I bought in 1998 with 400 hours on it, now it has 1550, it?s been a great tractor, only needed a glow plug over the years, and the rim rusted threw due to calcium leak., mine has the sss transmission also, Not knowing what you want to use it for, but I wouldn?t like the turf tires, otherwise they are great little tractors, my father has a 1520 also has had no problems with it. The bucket looks in good shape in your pic too. Good luck.
Yes, it stands for synchronized shuttle shift. You can push the clutch in, and change gears or forward to reverse without stoping, but you have to stop to change ranges. It?s a 12x12 transmission.
I plan on putting at least 2 ag tires on the rear as I am going to use it in the Berkshire mountains logging and trail maintenance--found Carlisle tires 12.4-16 for $220 apiece and am planning on tubes filled with used antifreeze. It has 1900 hours on it and its a 1998 should pull my 5 ft Bush hog much better than my 1310---has 9 more hp
If that ford is like KUBOTA you will need to change front AND rear if you are going to ag tires. Have to keep the ratio right on the four wheel drive or you will damage the drive line.
I suppose if the outer circumference of the tires is the same it shouldn't be too bad---and if i don't use 4wd on hard surfaces but only slippery ones that would help--but i did price front tires also as they are cracked too
You might be surprised what the turf tires can do or maybe not. How about chains front and back?
thanks--but they are so badly cracked that i don't expect them to last very long---I could run them till there flat but then I would have to change them up the mountain on steep land
That?s something to check into, however on my tractor when I bought it, the dealer put new optional 16? tires and rims on it, replacing the standard 14? ones. As was said don?t drive it on hard surfaces in 4wd.
I have a 1720 I bought about 10 years ago. It is a shuttle shift. I love it. Haven't had any problems with it or any needed repairs. My dad liked it so much, he bought one for himself about 5 years ago, and he loves his!
