Ford 2910 tractor starting issues
Good morning.
I have a Ford 2910 that has had electrical problems since I bought it (bought is used in 2003). The latest issue was, a couple of days ago I went to start it and it wouldn't start (solenoid clicking, flywheel barely turning). Checked the battery, it was putting out 12.6 V. So I jump-started it and checked the battery and alternator output - 12.6 V. I took the alternator apart, found bad brushes, figured might as well replace it. I replaced the alternator, jump-started the tractor - 13.9 V. I let the battery get charged up, turned it off, started it right away, it fired right up.
The next morning I tried to start - nothing, just clicking. The tester showed the battery at 8 or 9 V. I jump-started it again, let it get charged, checked the battery, 12.5 V. I figured maybe an electrical leak. So when I shut the tractor down, I took the negative cable off the terminal and left it that way overnight. This morning same deal - clicking, and 10 V.
What do you think? Bad battery, should I have also taken the positive cable off the terminal? I've got a bunch of hay down and this jump-starting is getting old. I am thinking of bying a new battery tomorrow, but I'd rather save $125 if that's not likely the issue.
Thanks in advance to all who answer.
If the battery was fully charged when you shut it down, and the next morning the battery was down after you took a cable off , then it's the battery.
Check your battery with a hydrometer and see what the readings are. I think your battery is toast probably has a dead cell. Hal
PS: Get one from Walmart that will fit your battery box. They cost about $77.00 w/exchange and have a free replacement during the first 3 years if the battery fails. I have 3 of them all over 8 years old. Hal
surface charge on battery will last maybe a couple of hours after running but not overnight charge battery with battery charger then test
You need to check the battery with a load tester. A battery can show voltage, but have no amperage. I had this happen to me on a 4610 Ford.
