Hi all, I'm buying a 3000 gas tractor that won't start. It had been "worked on" by the owner's friend, who pulled the distributor, and then replaced it after moving dist gear.
I've figured that problem out (among many others), and the spark wires now have to go to a different position on the dist cap than original, in order to maintain proper 1-2-3 firing order.
I can time it that way, but I'm thinking of pulling the dist body off again and restoring it to the original proper order on the dist cap. The cap is marked with a number "1" at the terminal which now is going to the number 3 cylinder.
My biggest pain in the neck right now is that the dist cap clips are positioned so that one of them is at the back of the distributor under the manifold, and nearly impossible to get to.
I'm wondering if this can be changed to be more accessible?
If you have a 3000, how are your dist cap clips arranged? are they like mine now -- nearly impossible to get to the one in back?
Thanks!
Thanks!
