ford 4500 loader lift problems
kyrr
"75 ford loader 4500:3pt hitch won"t lift..
i pulled the top off & freed up all the linkage .
replaced o rings/filter/new balls n springs in pump.
no oil showing when i pulled the lid off (twice)
are all the levers attached to the quadrant shaft supposed to move freely?(the one on the inside end did not so i freed it up)
no manual so i need to know how/where to ck pump pressure >>>
i"d appreciate any help /advice anyone can offer
Larry
Kyrr, soundguy is right. BTW, he helped me on pressure testing my hyd pump. Check the archives with his "name +pressure test".
Also, in my book it describes a gauge, I bought at the hyd shop for about 20 bucks. and relief valve setup to test the pump while it is on the tractor. The picture is unreconizable because it is so dark, or I would send it to you.
anyway, I plumbed the gauge (with a "tee") into the allen head bleed screw in the pump body. next the valve, (a brass gate valve for my water hose), attached to that was a hose (clear tubing, so i could see any bubbles) dumped it into the fill hole on the rear axle.
MAKE SURE THE VALVE IS OPEN BEFORE YOU START THE TRACTOR!!! TRIPLE CHECK THIS!!!
at a good idle, somewhat warmed up, start closing the valve. watch the pressure gauge, mine went to 1800 psi before the system relief valve opened. The pump checked out okay. I don't remember what the specification is. maybe 2200 output from the pump itself. but it was enough to let me know that the pump was good.
steve
