Ford 5610 electrical
foxhoun
Can someone help me with an electrical issue on a ford 5610 tractor. A bare wire shorted out when I turned the key on and now there is no lights and the tractor will not start. All fuses are good.
Power to solenoid and battery is good
Foxhoun
Not to imply insult but are you sure all fuses are good? I'm guessing you checked them in a fool proof way. Sure sounds like a fuse problem to me especially with lights not working. Do you have current past the fuse box to the lights and key? Burnt wire? Past that I'm at a loss. Maybe someone with more knowledge will answer. I have a 5610.
Have you cleaned/tightened all 4 battery cable connections? I've also seen battery cables that appeared to be good but had corrosion inside insulating cover & poor elect conductivity.
Use a test light (auto store cheap) start from post to post on the battery Light good no light battery dead. Next ground the clip of the test light to a shiny metal part on the engine, then test the non grounded terminal of the battery Light good, no light the ground cable is not connecting. next follow the non grounded battery cable to the Starter. Test that terminal and stud where it connects. Next follow the thinner (but not skinny) wire to the instruments. You may need to gain access to the back side of the instrument panel. There will be a burnt wire or connection, or fuse link somewhere. Jim
You originally posted "Power to solenoid and battery is good." Does that mean your battery is good and there is power to the solenoid via the battery cable, or something else? How did you check this?
If you have battery power to the solenoid there should be a wire from the same terminal of the solenoid, the battery cable is hooked to, going to the switch or a fuse/terminal block. You say a bare wire burnt when you turned the key. Do you know where one end of it is? Can you follow the burnt wire and find both ends of it? If it goes into a harness you may want to open the harness and chase the wire through, in case it burnt into other wires.
I am not sure the burned wire was hooked to anything, cant find the other end. I believe wire was
pinched Under hood.Checked the power to the solenoid with test light looks ok. Comes direct from
battery positive.
I will try to trace the wires tomorrow
You may want to post this in the Ford section.
Sometime posters on this site just monitor specific sections.
A Ford man can and will probably reply.
