ford 600 solinoid
chuck c
when i try to attach the negative wire from the battery to the solinoid the soliniod engages and turns the engine over.can you help?
Are there one or two small terminal studs on that solenoid?
Either way, disconnect the wire(s) from the small terminal(s) and tape them for safety and try again to connect the battery.
If the starter STILL runs, you have a bad solenoid.
If disconnecting the wire to the start switch has eliminated the problem, likely you have a bad/stuck/shorted starter switch.
You have the battery cable on the wrong terminal.Left terminal goes to the starter.Look for shorts to ground on small terminal or a shorted starter switch.
