ford 720 loader 19-249
FERRANTE1
So after searching all over for a direct replacement loader pump,looks like i will have to modify a replacement pump to get this loader up and working.has anybody done this? and if so what parts were used and pictures of installed pump. Thanks in advance
Well ... you have to be creative. My loader is a 703, but a 720 is basically a beefed-up 703. First choose a replacement pump as closely matched as possible (SAE mounting type, input shaft, rotation direction, GPM, etc.). I replaced the original Cessna with the most similar modern Cessna (Eaton now). After mechanically mounting the port styles, sizes, and locations will be different than the original. You have to visualize and come up with a strategy for adaptation. Browse the fittings, adapters, and hoses at places such as Surplus Center, Discount Hydraulic Hose, Northern, Baum, Bailey, local hardware, local auto supply etc. Come up with a plan then implement. Below is my pump, Rube Goldberg would be proud but it works.
<img src = https://i.postimg.cc/rFkNFRpR/703-Loader-Pump-Resized.jpg>
Thank you so much! yea i hate to cut up original piping but i think i will use fittings and adapt.the pictures you posted are very helpful and creative.
