Ford 8n electrical question
JD Bob
Does any one have a wire diagram for a 8n with front mount distributor and one for a side mount distributor with electronic ignition being added and also will be adding 12 volt conversions to both and 1 wire alternators to both
All pics and advice appreciated
I don't remember any JMOR diagrams that were for EI maybe I did not look. Google "jmor wiring diagram pdf" JMOR will be the key word. A word mix to narrow it down "jmor ford n ei wiring diagram pdf". A site YT will not let you post comes up they host his work it will come up as the N club.
Warning some that are not knowledgeable will tell you how S*tupid you are for even thinking about EI. The fact is they are skeered of EI and make up stuff to run you away from it.
