Ford 8n Propane Powered
-=CRANK=-
Good day everyone.
Just wanted to say hi to the forum. A little background about me, I grew up helping my grandpa with his Ford Workmaster 601. I'm not sure which year it was.
Since then I picked up a Ford 8n, propane powered.
I'll have to research the year. [color=lightgrey:c46e5e8478] Its a front distributor.[/color:c46e5e8478]
CORRECTION: Its a side mount distributor
I use it for shredding the property. The 8n has a lot less power than the diesel powered 601, but it does the job. I'm always amazed when I check the oil on the propane 8n. It looks like the day I put it in, always clean.
The shredder is a bit large for the lift to keep up, so my next install is a set of height adjuster chains, (on order) to relieve some of the pressure. Everyone I talked to about the propane engine told me that they were prone to overheating. Which this one did. I found a water pump at tractor supply in the clearance isle for $20, so I thought I'd give that a try. It hasn't overheated since. So far I'm very happy with the tractor. I do wish propane wasn't as expensive as it is now, but it looks like gas and diesel are catching up.
There are a few things missing from years of use, like the fuel level gauge. I'd love to find a print out or a picture of one, so I'd know at least what it looked like, if I should ever feel like constructing a replacement.
This post was edited by -=CRANK=- on 10/24/2021 at 07:34 pm.
Are you sure of that post a pix of the other side.. Front mount means it mounts to the front below the water pump a P.I.T.A to work on. A side mount mounts to the right front and sticks out the side you can service it without removal. All original front mounts had the generator on the right side.
(quoted from post at 21:37:17 10/24/21)
Correction, its a side mount. You are correct sir. Still learning about 8n's.
