JeremysGarage
Ok, this might be a little long winded.
I"ve got an 8N here a customer picked up. It seemed to run well when we picked it up but I really couldn"t test it much due to a bad trans. I"ve got that fixed along with many other parts bushings bearing seals guages blah blah blah. The engine, we were told that it had been over hauled by an engine shop. I"m sure that is true. it is very stong, no smoke and sound perfect. Except the sputter at idle to just below half throtle. runs good at full throtle with no load but after you start and stop a few times in 2,3,4 gear it stumbles and and spits and sputters untill you bring R"s down or bob the choke. that doesnt always work either. Ive tried adusting carb while it does this. It will clear out and then do it again after stop and go few times.
Poits are not new but are in good condition and clean set just a bit more than .015 maybee .017. timing set dead nuts continuity though points breaks at exactly 1/4 past top edge of left side mount hole.
Carb. well? I had to clean the previos ownes silicon messout of it and remove the rest of the original gasket. it has had a kit put in it. The jet, needles and throtle shaft is new as is needle and seat but the guy didn"t clean all the old gasket off and siliconed the new one in. WTF. From seeing that I wonder if he could have put the wrong kit in it. Don"t know if ther are different kits for the same carb body on these old MS"S
The other thing I"m not sure of is. This engine is quiet, almost to quiet. No valve click or so quiet I can"t here it over the exaust. Thinking not enough valve lash. Might need to pull the cover and check it out.
OH yeah this is an 8n28371 makes it a 47.
I"ve been working on late model stuff to long and I know I"m over looking something fairly simple.
Sometimes when you don"t know were to start, go back to da begining.
Just writing this helped the thought prosses a little bit
Please! if you have any good info for me, please post for me
