Ford Back Blade?
Thanks, that worked! Photo attached.
Why scrap it? If its not something you want, for just
a little bit of effort you could get $100 for it instead
of $10. If its not all bent to Shiite, that is
Im not a tractor guy but the previous owner of the property left behind a bunch of tractor parts & one tractor thats semi assembled. Ill post some more pics. Let me know if its worth cleaning up, thanks!
Maybe Ford made some implements that I'm not aware of, but that looks like the 3 point frame from a Ford dirt scoop, attached to some sort of grader blade. Perhaps homemade? If so, likely not worth
more than scrap value.
Ford Implements, usually no matter who the manufacturer was, were usually pretty good quality, I've got an 8' landscape rake
that is built with good quality. That is a rear scoop or looks to be, worth more than scrap unless totally trashed.
To start with, drag it out in the open and clean the dirt off of it so we can see just what
you have to work with. Rear blades are always handy.
