Ford Jubilee
I am trying to get a hydraulic leak stopped. the leak is coming from what Ford calls the hydraulic lift cover it is stamped with (NAA 476). there are 2 oblong slots for an O ring and 2 round slots for o rings. This tractor was setting for many years and I got it running, then hydraulic oil started to seep out from under the lift cover. I have tried several sets of o rings, about 5 or 6 sets. No matter what I do it leaks. I put a set on and they lasted about 5 or 6 days, then started leaking, thats the best I have been able to do. I do not know what I am doing wrong. It should not be this hard to seal this lift cover. I do have the then plate that goes under the lift cover. Any advice will be greatly appreciated.
My suggestion may have merit. There are O-rings made from Teflon based compounds that may provide a solution. Assuming the originals are actually the source of the leak. Cracked grooves, scratches in the grooves, or mating surfaces are also possible contributors. Jim
Info
