Ford Jubilee
Geo-TH,In
Can anyone tell me what is the best oil to use in the engine, transmission, hydraulic, and rear end in a 1953 Ford Jubilee. Some people tell me that I should get my oil at the Ford dealer, however I don"t have in my town. Others say that buying oil from Rural King will damage the hydraulic(3-pt lift) Can anyone set the record straight. Thanks in advance.
depending on your choice you can use good quality 30 wt,10-30 or 10-40 in the engine.
use tractor hyd fluid in the rear axle and trans,the hyd uses oil out of the rearhousing as does the rear axles
the napa store here sells tractor hyd.walmart sells it too i believe,or sams club.
on the pail it should say if approved by ford,ih,case,john deere etc.
As per the NAA owners manual you need to use SAE80 if temps are below 32 and SAE 90 if above but you can use one like the 80W-140 in the trans. Hyds M-4864A or equivalent, The rear end the same as the trans. It says use 30W if above 90 and 20W below but again you can use a 10W-30 or 20W-40 if you would like and be ok
Actually, the Jubilee/NAA does NOT use oil from the rear end for the hydraulics. (unless the seals are leaking!) There are 4 fill ports, 4 drains, 2 level plugs and 2 dipsticks on that tractor - engine, transmission, hydraulics, and differential.
Engine oil depends on the operating environment and engine condition. All my tractors, including my Jubilee, get 15w40 diesel rated oil, year-round.
Current recomendations from NH is to use NH 134D hydraulic oil (or equivalant) in the transmission, hydraulics, and rear end, as the seals between those compartments often leak. My Jubilee has been running 134 in all three compartments for more than 10 years with no problems.
You'll get along just fine with a diesel rated 15W40 in the engine and any reputable Hy-Tran type oil in the rest of it.
Something meeting the specs of Ford NewHolland 134D is recomended... but since there are no wet clutche or wet brakes involved on that tractor the actual specific hytran isn't all that important. It needs a GL-4 gear lubricant with somewhere in the vicinity of 10W30 or 20W30 viscosity.
There are a lot of products on the market that will cover that.
TDH from either Walmart or Canadian Tire is my pick...
Rod
