Ford steering shaft
wallace1943
I need CCW or left hands threads / spiral on shaft.
I can't use a D2NN3A710D and I need D2NN3A710E.
My shaft has CCW or Left hand Threads.
I can't use CW or Right hand thread Spiral.
I will consider Used or New.
Wallace1943
Hello Wallace welcome to YT! I agree with destroked,
forums operate a lot like computers, good input
information leads to good output information. It looks
like the parent company of these forums All States Ag
Parts may have what you are looking for if your
numbers are right l; you must have a Ford 515, 535,
4400 or 4500. Cannot tell you for sure if it is in stock, I
see many other parts companies that offer it say it is
out of stock. Just FYI, always run the part numbers you
are searching for through a web search, that is all I did.
The words ..Steering Shaft.. are a link to the part for
sale.
Steering shaft?
(quoted from post at 15:25:26 07/11/23)
It s always good to mention what tractor your working on
My tractor is 535 or 515.
no visible marking on paint but I saw one similar on net.
It was marked as 545. Note a 545 has no steering column with a spiral gear assembly.
wallace1943
Have you exhausted all possibility that show up in a
search? There is one from a placed called Griggs
Tractor and another from mytractor.us. I can post links
if you need them.
Does your steering box look like the one in
the diagram below?
If so, I think I have what you need.
Send me an email with your phone #.
(quoted from post at 01:54:52 07/12/23)
the diagram below?
I have a Ford Tractor 515,535,4400 or 4500 with bad Steering shaft.
My shaft has left hand screw Spiral and is 26 + inches long?
My part # should be D2NN3A710E.
I could see your picture post.
I am Wallace .
My phone # is 256 683 9549
(quoted from post at 11:51:06 07/12/23)
What s wrong with your steering shaft
I was in a brush pile and I used loader forks to move away from a stump. Then my Steering wheel would turn in all directions without any move in front wheels.
I removed Steering column and all the ball bearing were out the collar on Spiral shaft. Also there was one bad chip of Spiral shaft. It also looks as if my ball bearing race around the spiral was enlarged.
Not been able to find a shaft anywhere.
Send some help.
I am going to junk yard today.
thank
the diagram below?
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto158366.png>
I don't have your EMAIL address.
