Ford Tractor Identification
I recently purchased an old Ford 4600 and i'm trying to identify the year and specific model of this tractor. The ID tag underneath the hood is missing and i'm not sure I have found the right location in finding the serial #. There are 3 sets of numbers on the right side block (around the starter) but the numbers don't seem to match anything in the tables i've found so far. There is a D5NN6015 G and also a *D380552* stamped nearby. I'm I looking in the wrong area? I think some of the numbers pictured may be part #'s and not the serial # i'm looking for. I have included some pics for your review. Any help identifying this model would be greatly appreciated.
Thanks,
Roger
Thanks for the guidance on the exact location! It looks like I have a 1979 tractor, but i'm still trying to decipher the model type, etc.
The stamped numbers appear to be:
DW3140
E25B
C610660
Is there any other pertinent info i'll need when ordering parts to restore this tractor?
Thanks again for all the help!
Best Regards,
Roger
Those are the number needed
Model # DW314D
DW3 = 540 industrial built 79-81, 540 is a industrial version of a 4600 Ag model
1 = diesel
4 = independent 540 pto
D= this letter is not used in the transmission codes, most like likely a C if it has the standard 8x2 transmission
Unit # E25B has a beginning number missing
Serial number is for a 79 model so the code should be
9E25B for a build date of May 25, 2979 on day shift
Sa said serial number is for a 79 model tractor built in the US
