Since I cut the centers out of the original 9 bolt duals I had to make a set of clamp on duals for my 3020 I?ve been looking for another set to replace them the calcium had eaten the first set pretty bad I didn?t feet to bad about cutting them up . So with this set I?m going to pull the dual hubs off the 4020 and put them on the 3020 need to find a set of smaller wedges for the smaller 3020 axles then I can use the clamp on duals on the 4020 and I?ll be able to put two more sets of weights on each side of the 4020 I was originally thinking of cutting enough out of the center of the weights to fit over the dual hub and then use the spacers I have to still be able to bolt the dual rims on
