Free energy again
37 chief
How about a inch black iron pipe the same one mile length in the hot sun. charge it with 100 lbs of air. It will keep building pressure from the suns heat. Hook the line to a turban turning a generator. free electricity. Sounds good. Stan
Seems to me that you have a 100 lbs of pressure that would increase in the heat of the sun, but you would have NO air flow.
He is tongue-in-cheek As the last molecule of nitrogen is heated to a scorching 2,000,000 degrees and ionized 2 clouds deep, it whisps out of the end of the pipe at 1 mph, and hits the turbine blade firmly creating 5 mega watts. Jim
A few comments:
1 - The only "free" energy is from pressure rise above the original 100 psi pipe charging pressure.
2 - The energy gained is actually solar - heat from the sun raising the temperature of the pipe and air within.
3 - A calculation shows amount energy that could be extracted from such a setup is modest - only a few hundred watt-hours (or fraction of a kilowatt hour if you prefer) for each charge/blowdown cycle.
I'll spare you the drudgery of the math...
