Front loader for Massey 65
Hello. I just installed a front loader on my 65. Am not getting pressure to lift or operate the bucket. Do I need a diverted valve. Currently have supply and return from control valve to ports on each side of the tranny, under the seat. Any help is greatly appreciated.
Thank you.
To use the internal pump you need the valve that mounts to the top of the transmission in place of the plate. When using the factory valve setup; center the left lever, set right level forward, set the position control to constant pumping and use the loader control. To use the 3 point hitch; center the right lever and set the left lever to the rear. You will need to move the position control out of the constant pumping position.
