Fuel injector cleaner
SVcummins
Always used atf or commercial injector cleaner but everyone Says two cycle oil
i use 2 cycle also and dipetane fuel treatment. i keep the atf for the transmissions where it belongs. have never put atf in injection systems.
I have only ever used atf and it works fine there are no clutch packs in your fuel injectors or pump
Atf is a great lubricant and detergent and a great injector cleaner.
I spent a decade at a vw shop. Was common practice on older vw diesels to remove fuel lines from fuel filter and shove them in a new quart bottle of atf propped behind passenger headlight and let the vw run the the ATF straight as you worked on another car. Watch the clock and shut the engine off at about 40 minutes because 45 minutes will run the bottle dry and then you have to bleed air out if the injectors.
On the gas engine application, a quart of atf in the last tank of fuel before winter storage helps prevent sticking valves on our small fleet of air cooled Wisconsin single, twin and v4 engines.
Not saying it is law.
Just sharing what I have seen.
At this rate itll never run again been 60 days straight with no day off calving cows Monday And Tuesday and Wednesday Im drilling peas and barley was supposed to be today but we got scours bad and had to rope anf doctor calves all day finally got home got the duals on the tractor need to weld a press wheel and still havent greased anything yet . My real job Is calling they are ready to go Im wore out and its the first of April . Oh and and I have another tractor split to get together yet
I don't know. I read where Richard and others put in 2 stroke oil but every time I go price it somewhere (even at wilfart) it seems too expensive for what it does.
I keep atf around as that is what they recommend to use in my 12 volt hydraulic pump for the bale mover in my pickup. Also had an old case of atf in the back corner of the garage when I was going to change the trans fluid in my old 72 Dodge and never did and then started driving fords which took a type F.
