* Gas Power Air Compressor ?? **
Dutchman
I have Question on a gas power air compressor...
I recently bought a 10hp wis .. 2 stage air compressor... the tag on it {what I can read } says it's a 1957 .. max air 210 psi .. max temp 650f ....
SHOULD I replace the pop valve and relief check valve { I don't know if they work or not } I don't want to have a BIG BANG ...
THANKS for any advice .... Mark
Hope the pictures help..
In the end of the valve is a hole for a pull ring, run it up to the max PSI it will build, and then pull the ring. If it pulls easy it is fine if it pulls hard or not at all the replace.
