gas tank cleaning
doorman
When you wash a gas tank with muratic acid , how much do you need to use and do you dilute it at all? Also, do you need to use any kind of a neutralizer? Thanks for any help. doorman
How much I use depends on the amount of rust to be removed. Try a 1/3 part acid to water for light rust. I have used full strength being careful and checking every few minutes. For heavy rust, you might want to drop in a few small bolts for aggitation, being sure to remove all when finished.
Neutralize with baking soda. Be aware that rust will form instantly and pin holes may develop. Be sure to use a good tank sealer when tank is completely dry.
Don't forget fuel lines.
I use full strength Muriatic acid then wash out with clean water. Then use a pint of MEK solvent to absorb water, throw away and do it again with new MEK. You are ready for tank liner then.
