Hello all. Didn't see an introduction topic room, so saying hello here. I've bearing tearing stuff apart and putting it back together since I could hold a wrench, which turned me into an elevator mechanic 30 some odd years ago. Guess I'm getting better at repairing stuff, cuz I don't seem to have as many jars of spare parts when I get it put back together. I don't have any equipment, so unless you're close by and need use of some crooked fingers or over stretched muscles, I probably won't be of much help. But I have a buddy who has a couple of older units, and is often in need of help. An old Ford tractor, and now a Case 1740 skid steer. Haven't found the serial number for the Case yet, but guessing it's not to many years younger than me. I just had a set of manuals delivered for it, but other than that, I've been unable to find information online about this unit, which is how I wound up here.
When he bought it, he was told it had a left side steering issue, but when he got it home, it turned out to be a bigger issue. I took the floor pan out, and watched as the gearbox was bouncing around like a jackhammer. After some creative, and newly created swear words, managed to get the cross member out. The gearbox mount had broken away from the cross member, and after getting it cleaned up, noticed that it had been repaired at least a couple of times. So my question(s) are:
Are there supposed to be isolation pads under the cross member?
Is it a drive shaft alignment problem that is causing the force to snap the steel and welds?
Is there possibly an issue with the gearbox that could create the force necessary to crack steel?
Thanks all for taking the time to read and respond. Hope you have a great New Years.
