Got some spraying done
SVcummins
Killing sagebrush and some other weeds mostly sagebrush it?s amazing how the grass has improved just in the few areas I spot sprayed last year
p
A week or two ago I noticed that Bittersweet that I sprayed last fall is coming back nowhere near as strong as it was. That stuff was taking over the tree lines.
What are you using to control the sage brush. Maybe it would be tough enough to kill off buck thorn, I have been using Grazon xl with some success.
No grouse out here . The dead plant will still stand for years which is good because it can still help ketch snow but it doesn?t rob moisture or nutrients from the crop
I?m going to hit the brush I did last year one more
time label calls for two applications it?s 99 percent
dead but there is a tiny bit that?s coming back
Larry No I?m usually cutting grain trying to put up meadow hay and moving cows during hunting time . The one picture you can see a couple cow elk
muleman51 I?m using lv4 it takes a pretty high rate label calls for two applications but you can only put a max rate down per year so I have been doing one application per year . Look up tordon Is labeled specific for brush
