Hi guys I have a 49 8N I purchased about a month ago. The previous owner told me that the charging system was not working and he was having to take the battery cable off every night. Upon inspection after I got it home. I noticed some very creative wiring. I took the generator off (6volt positive ground)Inspected it, and someone had put the wrong brushes in it. They would not even move in the brush holder.
I decided that the generator should be rebuilt, and took it to my local alt, gen, starter repair shop. While it was there I decided to get rid of the creative wiring. NAPA auto parts sells a replacement harness. While I was running wires I put new copper core plug wires on it. I went ahead and installed a new voltage regulator.
Once I got the generator back I installed it, and made sure the battery had a good charge. I hooked the battery up polarized the generator by using a screw driver and crossing the bat and the arm terminals at the regulator. I cranked the tractor and got no charge! I checked it at battery and all I was showing was the 6.2 volts that were in the battery.
Today I decided it was going to be the day to fix this issue. I took the generator to a different shop just to have it tested. They said the generator was working very well. So the generator was not the problem! I pulled my service manual, and checked all the wiring. Every thing was in the correct place. The repair place had told me that it could be that it is not getting a good ground, so before installing the generator I pulled out the roloc disk and removed all the paint and rust from the connecting surfaces. Then removed the regulator and did the same thing. Everything hooked back up polarized the regulator and cranked it and got noting.
I took the VR off and returned it for another. Put it on, and went through the procedure. When I cranked it the amp meter moved up to about 2 amps at a idle when I throttle up to 1000rpms I get around 12 amps. At the battery I am getting 6.8-7 volts depending on the RPMs.
So it looks like all is good. That is until I turn the tractor off. I went back about 30 minutes later, and it showed no charge! I polarized the generator again, and it started charging again. Turned it off, come back a hour later, again no charge until I polarized the generator.
I am sorry for the very long post, but I figure some of the tractor gurus here may have run across this before. Am I losing ground after I cut the tractor off? I googled the problem with no luck.
