andydap
hi everyone, looking for new head bolts for a 1650 oliver diesel with a waukesha engine. these are 9/16 bolts. didn't even see used ones. the ones i have are at least three or four times torqued. any opinions?
andy
Sounds like IH with those old odd sized bolts in 1/16th sizes. Seems like it would just made sense to have used 5/8 and been done with it. Like an H is\t has 7/16 , 1/2 would have been better and more common to get or use and just more practical to me. I rarely use a bolt of the 1/16 size for anything.
I just finished putting a 310 together using 9/16 ARP head studs. The issue you will have is the bolt with the oiling hole that feeds the rocker shaft. I plumbed a line from the oil gallery thru the end of the head. You can see pics I posted on the Oliver section if you decide to go that route?
