Help with LP Tractor Valves Please
The LP Valve on my Farmall 450 is leaking. I thought it'd be simple to fix, so I called the propane delivery guy. I emptied the LP tank. He can't find a valve or valve parts. What do I need (probably)? Where can I get it? Is it so easy that I can do it myself? Thanks, kelly
I need the parts or the valve for the LIQUID. FYI looks to me as if the valves are identical??? I also have an Oliver and it looks to me as if it is the same valve??? Thanks, kelly
Your LP guy is not looking very hard. I just got a pair from AGCO for a couple MM tractors so I know they are available. I would think CNH should have them. Tank fittings and valves are pretty much standard as the tanks were all bought from vendors. I usually use my LP supplier but I needed these quickly so I ordered on-line from AGCO as they ship very fast.
They are called motor fuel valves take note you can get straight or angled outlets. easy to change screw them out and put in new ones.I would replace both.
