(quoted from post at 09:45:02 05/03/19) the "10" usually means 10 thicker as the crank has metal removed so the bearing must be thicker. Under size would be the crank as it has been ground. There are no undersize bearings but there are oversized to fill up the space when the crank has been ground.
(quoted from post at 12:39:12 05/03/19) "10" bearing will be 10 thicker than standard just mike one sometime
