Here is a off the wall question
gmccool
Location
Minden Iowa
Some implement rims have small valve stem holes for small diameter valve stems on inner tubes. Some implement rims have larger holes for the larger diameter valve stems on inner tubes. What is the thing called that you slip over a small diameter valve stem when you put it in a rim with a larger hole. I know what they look like & I would guess it is called a bushing of some sorts but what is it's official name. I need two & don't know what they are called. Thanks Gerald
