Hesston 1090
Bbrooks8159
I am working with a Hesston 1090. Had to remove the reel and destroyed the end support bearings to do so. With that said i looked on the agco partsbook website and found two bearing numbers. #712471 for the left side and # 713198 for the right side. It appears i may have found a cross to the right side listed as "Y713198" but am not 100% sure. Although partsbook shows the # and the part is doesn't show it as being something i can order and does not show an updated #.
Does anyone have any updated #s for these bearings or a source to get them ?
Thanks in advance
What kind of bearings are they?
Most manufacturers build around stock readily available bearings. Have you
tried a bearing supply?
Sorry I have no idea what kind of experience you have
with ag machine repair. Does it look like the example
bearing in the link and the outer race is clamped in two
stamped steel holders by usually 3 or 4 bolts?
Common item any implement dealer, farm store or
even most auto parts stores in rural areas carry them.
Sized mainly by shaft diameter. FYI the outer ring or
collar is turned by driving with a punch then the Allen
Lock screw is tightened.
Example
Yes it does look like that bearing.
I ended up going to a "farm depot" ag store and the parts guy was able to find updated #s for the old superseded numbers.
In case someone in the future is looking the reel bearing #s for the Hesston 1090 are as follows
71306662
Y713198
Thanks for everyone's help
