Hiil drop 1594
Doug Wi
Have you solved your problem yet? Does you have the dual pump setup? There is a lever in the cab, right side, that can either split the pumps output ,one to the 3pt and the other to the remotes . In the combined position. all the output is directed to either the remotes or the 3pt. Can't remember which . Possibly the lever in the wrong position or a malfunction with that valving system could be causing your problem.
