hitch on back
caterpillar guy
I am thinking a fifth wheel type of hitch for the back of the disk or field cultivator to pull a packer. This would be to make it easier to do alone. Pros and cons hear would be great. Mine is the dust and wear. I am thinking like a smaller model of on a semi like the camper crowd would use. This would be on 30 foot or so equipment. This instead of working getting a draw pin in a hole.
Make a gooseneck hitch for the packer and use a 2 5/16 ball on the disk/cultivator. Then just a regular female gooseneck receiver for the packer. This will allow it to not only turn but pivot side to side. A fifth wheel type hitch does not allow side tilt/twist. So crossing ditch at an angle would stress the hitch. You can also turn shorter on the ends if you make your hitch arch long enough.
I made a hitch like this in the 1980s to pull my JD 8300 drill behind a cutlimulcher. Made it a single pass tool. Really made running soybeans nice with the smooth ground.
JD I was looking to have more tolerance for error when backing in to hitch up. The reason for the fifth wheel deal. The ball has to be about right on. I was looking at some of the RV type ones they have a sideways flexibility to them also. Not sure just what to do. I am the lone labor a lot of the time.
Look at the Quick bite couplers. I have several of them and I love them. They make hooking up by yourself easy. You back into them and they auto latch.
I'm not sure they will stand up to the kind of pull you can get with 30' equipment, certainly would need fabricated mounts and likely strengthened pivots. JD seller's idea of a ball mounted where you can see it would allow you to maneuver under it and raise into it.
We had a 2 5/16 ball on the vibra shank and a coupler on the drill it works good and a lot easier to hook up than a draw pin
Well, I can see some fabrication on the packer hitch to funnel the receiver with a fold down leg to hold it up, and to align it onto a ball mounted on the disc harrow as JD said.------------Loren
A fifth wheel hitch for a camper typically has around a 14,000# capacity. Likely wouldn't stand up for what you want to do.
