Cariboo4x4
So I though master cylinder was shot on this 1977 International Loadstar 1700 so I replaced and still same symptoms: press brake pedal 1st time it sinks to the floor. Then on 2nd through 4th pumps it stops 1/2 way down. Then if you wait 1 minutes the same thing happens. Pedal goes to floor yet on following pumps 1/2 way down. I have replaced slave cylinder and service the wheel cylinders that were leaking on front and rear drivers side of truck. I been told I need to pressure bleed brakes to get rid of trapped air that may be causing the the pedal to sink to floor. Im thinking of applying 15 psi to top of master cylinder with air hose yet it seems these pressure bleeders have a remote pump that contains brake fluid that you pressurize to master cylinder. Anyone here made a pressure bleeder set up?
