horse power
Flat ground or hills? What speed? Pulling down the lane or in the field? Not near enough information to give a meaningful answer!
(quoted from post at 19:35:08 01/09/23) If it is a 'NO TILL seeder, it might take 80 to 100! If the ground is hilly maybe more. If it is a disc opener seeder, maybe 60 on well prepped ground, or 80 in hills. Jim
ot to mention soil type/wetness/dryness, width/on & on. It will all be in the details.
o.k. so, the ground is generally flat, not muddy done after harvesting wheat. no duals, no four wheel drive, and the unit is about 12 feet wide with a coulter in front of the double disc.
ooh , just saw its 8000lbs, 12 ft wide. better post a picture. i pull my 12 ft ih seed drill with my 560. its no where near 8000lbs. get us clued in here.
I dont see why an 80 h p tractor wouldnt do the job. But when u compare an 80 h p new tractor to my old 660 which is 87 h p. The new tractor will be struggling while I wont. So u need to give a tractor make and model also. For example my neighbor bought a new john Deere in the over 30 h p range. I know it will not pull what my old w4 will pull at around 30 h p also. So h p is not an accurate judgement here . The old h p is in Clydesdales and the new h p is in Shetland ponies.
Andy, I pull an old bushhog/lilliston drill that is approaching that kind of weight (7000# give or take) with an IH 3088, so about 80-90HP and weighs 10,000+ lbs. we have hills here and it does ok for us. Our drill is an 18 hole drill, yours will probably have a few more which could need a bit more power but I typically can run 4-5 mph all day with ours no problem. how deep you need to plant will also affect how much power/traction you will need. Around here (swPa) forage/grass/cover crops are usually seeded pretty shallow, 1/2 or less so less power needed. If you sink it deeper, say for beans 1 1/2 - 2 of course harder pull need more umhpah to get it done. Hope this helps some, Paul. I should add this is a no-til drill.
