hyd. cylinders
I need a couple for a skid steer back hoe, mine has one cylinder that has chains pinned to each end of the barrel and as you may know it broke the ears off the cylinder and now it is time to repair I think it would be better to have 2 one on each side to make it swing side to side. The chains have always been a prob.and that is prob. the reason all the newer machines have 2 cylinders. I think they need to be around 12" to 14" closed and I can figure out the rest later. I would like to window shop on-line and get an idea of what the project will cost. Let me know if there is a place you like to look that will give all aspects of the cylinders. Thanks, Roy
Go to www.northerntool.com
Also search the web.
Parker fluid power makes lots and lots of cylinders.
Other manf. Prince, Gresen, Energy. to name a few.
Lots of stuff to look for in cylinders, seal types, mounting hardware, double seal, hydraulic porting etc.
Good luck.
Try: www.surpluscenter.com
Have used them a lot. Always great service and best prices I've found anywhere. You can get a free catalog form them at that site also.
Good Luck
