OK, this really isn't an antique or even vintage tractor. We have a MF from around 1990. It has hydraulic only steering. That is, there is NO mechanical connection between the steering wheel and the front wheels. There's a pump with two lines, and a ram on the left side. I know there's no mech interface because when we had a line break - the wheel can be turned round and round and round, and the front tires go nowhere.
On to the problem we're having. Before the line broke, the steering was already very vague At idle, the wheels would barely move with the steering wheel. At 2100, the steering is better, but the wheels still bounce around with the steering wheel held tight. I presume it was a lot of air in the steering circuit. I've hunted around for a proper bleeding process but so far all I can find is fill, or refill tasks. The pump is right behind the dash, and the lines go down to the ram on left.
My method is to use a syringe and drive fluid into the back line of the ram all the way up to the pump/drive, and do the same for the front line. After that, I can worry about any air in the pump/drive by cracking the lines and turning the steering wheel all the way left and right a few times.
If there is a better procedure, I would welcome some advice. I have a pan to catch the fluid overfill under the tractor. Maybe there's a better way, and I just don't know it. I'll have two new lines in a few days and would like the steering to work as designed.
